Do I need a clutch kit if I get a new CDI?
Old Nov 30, 2007 | 09:41 PM
LeftInTheDrier's Avatar
Default Do I need a clutch kit if I get a new CDI?
If I get a new CDI upgrade for my quad, do I really need the clutch kit or is it alright without it? I've been killing myself trying to find this stuff with out. If I need to spend all that money than I'm just going to say f-it and save my money.
Old Nov 30, 2007 | 09:58 PM
BMotorsports's Avatar
What type of machine is it
Old Nov 30, 2007 | 10:08 PM
2003 Predator 90
Old Nov 30, 2007 | 10:17 PM
A polaris with a variable ratio clutch? (snowmobile type clutch) Is the CDI have a higher REV limiter?
Old Nov 30, 2007 | 10:38 PM
I'm going to be loging off soon so if it has a higher rev limiter you don't have to re-clutch but it would be pointless because it changes the powerband therefore changing the shift point on your driven clutch therefore you lose power when the belt slides down into it. It may shift to soon and anything youve added for RPM will be lost and you won't gain anthing. Only replace if you have to otherwise you'd be better just tuning the clutch you have.
Old Dec 1, 2007 | 08:54 AM
<div class="FTQUOTE"><begin quote>Originally posted by: BMotorsports
I'm going to be loging off soon so if it has a higher rev limiter you don't have to re-clutch but it would be pointless because it changes the powerband therefore changing the shift point on your driven clutch therefore you lose power when the belt slides down into it. It may shift to soon and anything youve added for RPM will be lost and you won't gain anthing. Only replace if you have to otherwise you'd be better just tuning the clutch you have.</end quote></div>
Yeah it's a CDI with a higher rev limiter. So are you saying that I shouldn't get the clutch kit and the CDI?
Old Dec 2, 2007 | 05:24 PM
If you plan on getting both that's perfect
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
