05 Rincon 680 Rev Problem
Old Dec 27, 2007 | 01:02 PM
Scheer's Avatar
Default 05 Rincon 680 Rev Problem
A few days ago I was pulling my brothers around in a sled behind my fathers Rincon and just as i was going to pull it in the garage the RPM's suddenly spiked up and it fell out of gear, but the **** still said it was in D. Now every time it is started, it will rev at a normal level and then after a few seconds it will spike up again. If it is in a gear when it revs up, i will internally go into neutral but say it is D and if I give it enough throttle, the RPM's will drop a bit and it will start to move again... but the second you let off throttle it will rev up really high. I checked the throttle cable and it is not seized in anyway, also since it has the efi there is nothing on the carb that i would understand how to adjust. Any one have any ideas on what caused this and what the solution may be? Thanks much
Old Dec 27, 2007 | 01:51 PM
JeffinTD's Avatar
I don't know why the display is still showing D when it's in N, unless it wasn't all the way into the N detent, but the reving up thing might be due to the IAC hanging up.
If it's still under warranty, let the dealer mess with it. If not remove and disassemble the IAC to remove the factory grease and replace with light oil.
Welcome to the forums.
Old Dec 27, 2007 | 02:01 PM
Gimpster's Avatar
The shift cable is Slightly out of adjustment
With the IACV sticking it is magnifying the issue
----- Gimpster -----
Old Dec 27, 2007 | 02:10 PM
Scheer's Avatar
Alright i'll take a look at it this afternoon, thanks much for the help guys.
Old Dec 27, 2007 | 02:25 PM
JeffinTD's Avatar
Didn't think abou throttle cable adjustment... Should be 1/8 to 5/16 freeplay at the end of the thumb throttle. If there isn't there is an adjuster on either end of the cable.
Since this cropped up during the cold, it made me think about the IAC since there have been threads about them sticking apparently due to the grease getting thick in cold weather.
Old Dec 27, 2007 | 02:43 PM
Scheer's Avatar
It was the IAC, it needs to be taken apart and the grease needs to be cleaned out and replaced with a light oil (as i found on another forum). It had also said to tap on the IAC with a wrench, i did so and it did fix the problem. Later when i have some more time I will replace the grease but this was a simple temporary fix. Thanks for all the help.
Old Dec 28, 2007 | 02:25 AM
Gimpster's Avatar
Well, I don't want to pop their bubble, but the IACV is installed dry. No oil or grease. If an oily or greasy substance is on the IACV from the factory, it is the shipping coating has sucked into the IACV slide and has gummed or hardened up. No where does Honda recomend oil or grease on the IACV during install.
Old Dec 28, 2007 | 02:56 AM
JeffinTD's Avatar
I don't know if it's grease or some sort of contamination that resembles grease, but if high idle suddenly crops up during cold weather, cleaning whatever it is out of the inside of the IAC seems to be the cure...
If you rap on the IAC with a screwdriver handle while it's high idling, if it temporarily returns to normal that seems to confirm the diagnosis.
I know nobody greases them during install, but is there grease up inside the IAC from when it's built?
Old Dec 28, 2007 | 01:09 PM
Scheer's Avatar
I'll let you know of any kind of oil or grease if it is in the IAC, at the moment I am just waiting on a safety torx bit to get to it... And it is still running fine after tapping on it yesterday, and it has even been rode around in the snow for a few hours.
Nondem
Feb 22, 2020 12:20 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
