poor fitting plastic....any tips?
Old Jan 17, 2001 | 09:10 AM
xpedition2's Avatar
side fenders don't fit tight, seat almost seems to be out of adjustment. i have heard heating the plastic helps. i also cracked the bottom tab slot on left rear side removing the side panel. it is still under warranty, will polaris cover this?
any input would be appreciated.
Old Jan 17, 2001 | 10:41 AM
xpedition2's Avatar
surely someone else has or had this problem??
am i destined to have a brand new xpedition with ill fitting side panels?
Old Jan 17, 2001 | 12:16 PM
waynaferd's Avatar
On my TBlazer, where the front and rear fenders meet under the seat, were kinda "bulged out", I guess. The seat got a small tear from the front fenders being pushed out. On mine, there was a small metal tab that the fender screwed too, and I just pushed real hard on the fender till the tab bent in. It looks a lot better now. I'm not sure how your plastic is secured, but if it doesn't have any bendable tabs, then heating the plastic should do the trick. Just don't melt it!!!
Old Jan 18, 2001 | 05:40 AM
xpedition2's Avatar
t.y. fasternu. i may have to experiment a little. i am not having much luck finding relevent info in old posts. maybe some xpedition owners will happen across this and give me some tips.
Old Jan 18, 2001 | 09:38 AM
bowtiepu's Avatar
my expedition as well as my magnum before didnt have great fitting plastic,nor do any of my riding buddies machines(polaris) have good fit..the side skirts that clip to the frt fender and the rear is the worst..honestly it doesnt bother any of of us bad enough to even deal with it so,it doesnt look that bad..try loosening it up at all points where it connects to the frame and try to move it around..good luck
Old Jan 18, 2001 | 10:36 AM
TEXMud's Avatar
You Polaris owners arent the only ones with this problem. It seems I have it too on my Hondas. After removing the plasitcs and putting them back multiple times, nothing fits together like it used to.
Old Jan 19, 2001 | 12:19 PM
DJ425's Avatar
Make sure all the bolts & screws are in. My Xpedition was missing 2 of them. The front plastic didn't seem right, & when I took it apart I found a couple of missing screws.
Old Jan 19, 2001 | 06:15 PM
Pfelect's Avatar
My Xped side panels dont fit exactly right but it has never bothered me to the point that I would try to fix it. I read somewhere that you can adjust a little by the gas tank where the plastic bolts there, I think you would need to pull the plastic down at that point to get the side panels to fit better.
Another tip...
Get your quad as muddy as possible and no one will notice that poor-fitting plastic!
Old Jan 21, 2001 | 09:02 AM
stuart40's Avatar
Just be a little patient when removing any panels.They will come out with some effort. The panels have to be tight or they will fall out on the trail. {try a hair dryer on low heat and from a distance[ 12 inches ] away from the panel.
This is common in most brands of atvs.
EIF
Apr 20, 2017 07:15 PM
Beeline08
Nov 11, 2016 04:00 PM
tysonbully
Sep 28, 2015 02:30 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
