I stripped the front hub drain plug, then broke the 'easy-out' inside the pilot hole!
Old Aug 3, 2008 | 12:25 PM
thefed's Avatar
Default I stripped the front hub drain plug, then broke the 'easy-out' inside the pilot hole!
Title says it all....stripped the drain plug, tried to remove with easy out, and it snapped in a 1/2 second....now it is stuck in there pretty good.
If I were to drill a new hole right next to the existing drain plug,would I hit anything? I'd keep it at the same position so the 3 or 4 o'clock fluid filling technique works, but move it toward the outside of the bike some?
Any ideas?
Old Aug 3, 2008 | 01:01 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
wow thats sound like what i did on something totally differnt. i would bet there is something in the way of drilling a another hole maybe. try to look at a parts break down of one or maybe someone w/ extensive knowledge of one of them will know for sure.
Old Aug 3, 2008 | 01:56 PM
MECHANIKE's Avatar
you can drill another hole,but it has to be exactly in the same circle cause there is a bearing race to+fro...........................................
Old Aug 3, 2008 | 05:10 PM
thefed's Avatar
whaddaya mean 'the same circle'? you mean the same exact distance from the edge?
Old Aug 3, 2008 | 05:32 PM
Indslpwr04's Avatar
Sounds like a bad day bud. Yes he means it has to be the same distance from the edge of the hub where the cap screws on. Every time i filled the fluid up i would put a little dab of antiseise on the threads.
Old Aug 3, 2008 | 06:39 PM
MECHANIKE's Avatar
yeah,when you take it off,you'll see bearing races on either end.right next to the hole..........
Old Aug 3, 2008 | 09:36 PM
thefed's Avatar
yeah this sucks. i found a hub in great condition i almost wonder if i should snag it for 75 bucks.....
Old Aug 3, 2008 | 10:07 PM
MECHANIKE's Avatar
just drill the hole right next to the other,right next........
WilliamBos
Sep 30, 2015 08:08 AM
DOAinNY
Jun 12, 2015 02:26 PM
DOAinNY
Jun 11, 2015 10:34 PM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
Biggieshortie89
May 26, 2015 08:01 AM
