clutches
Old Jan 29, 2001 | 05:31 PM
lelindse's Avatar
I cannot get the nut off the shaft of the centrifegal clutch on my 97 Honda Recon. This model ATV has two clutches. I was able to get one nut off using an impact wrech but the other one just will not come loose. I have tried an eletric and air operated impact wrench. Can someone help me?????
Old Jan 30, 2001 | 07:04 AM
Diogenes's Avatar
If you block the shaft from rotating (best way, use a Honda gear-holder, but only a Honda dealership garage is likely to have one, shade-tree way, jam the gears tightly with a rag), apply all the penetrating oil you can find to the nut, and MAKE SURE YOU'RE TURNING IN THE CORRECT DIRECTION (check for left- or right-hand threads), an air impact wrench should have enough torque to remove the nut. Blocking the shaft normally isn't necessary with an impact wrench. Be patient; let the wrench beat on the nut as long as it takes. If this approach doesn't work, sounds like the old ball peen hammer and cold chisel routine (a Moto-tool cut-off wheel might at least give you a start and save some time if you have to go this route).
Diogenes
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
