Speedometer Hall Sensor
Old Nov 15, 2008 | 11:23 AM
chikester's Avatar
Default Speedometer Hall Sensor
If a new hall sensor is needed do you recommend getting a new sensor cap as well? Mine apparently needs sensor as speedometer is not working. All esle as speedometer works except registering the speed. Thanks.
Old Nov 15, 2008 | 11:39 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
its not just a broken wire is it? if i was replacing it i would go all new to save the headacke in the long run w/ any parts. imo
Old Nov 15, 2008 | 02:01 PM
TLC's Avatar
TLC
Yes Check the wire fist and clean old senor first. What is a sensor cap? I changed a Hall Effect once and it came with a new wire and senor,all there was needed.
PS my new $80 Canadian senor failed after only a year so I just gave up on it and have no working speedo for two years. I judge my speed by how fast the trees are flying by now.
Old Nov 15, 2008 | 09:34 PM
Depending on model the early sensors didnt have the aluminum cap in front of sensor head. Even when you order sensor,cap not included. I dont replace/order cap,unless damaged!
Jeff Roper
Feb 1, 2022 11:48 AM
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Jeff Roper
Sep 21, 2015 02:11 PM
rawbdiggity
Sep 7, 2015 12:05 PM
