02 Sportsman 500HO
Old Jan 18, 2009 | 04:04 PM
DarrenWS6's Avatar
Default 02 Sportsman 500HO
Hi. In October I bought a blue 02 Sportsman 500HO X for $4200. Had 1600 miles, and came with a 2500lb winch. This is my first ATV, i'm not very mechanically inclined when it comes to ATVs so I thought I would introduce myself and ask a few questions.
Maintainence wise,
1. What oil and how many quarts should I use for it and how often should I change it? and where do I buy the oil filter?
2. I need to change my fuel filter because if it idles too long, it dies out. What part # or where do I buy from and what procedures are necessary for changing?
3. I would like to get a better air filter, what would be suggested?
4. It doesn't like being ran in the cold too much, how do I adjust the idle to run higher? and where is the carburetor on this thing?
Now customizing wise,
1. I would like to get some sound out of this thing, what are my options for exhausts? I really like the sound of the Big Gun kit. http://www.youtube.com/watch?v...8&feature=channel_page Its deep toned and aggressive under throttle, perfect. Where could I buy from, or whats better suggested out there?
2. I would surely love to lift it, or atleast get the front end leveled with the rear, what are my options?
3. Is there any way I could get HIDs? I have the clouded lenses, could I upgrade to clear lens headlamps?
4. As seen in that video of the Polaris with the Big Gun exhaust, where can I get those hand guards for the handles?
Thanks to all who read.
Old Jan 19, 2009 | 06:26 PM
DarrenWS6's Avatar
bump.
Old Jan 19, 2009 | 06:41 PM
TLC's Avatar
TLC
STP SMO17 ,Napa Oil Filter #1358 or Fram CPH6607 There are many more substitute parts here use Amsoil 0w-40 or the Polaris dealer stuff,both are full synthetic oils.
Either your idle screw is set wrong (bottom of carb) or you have to adjust throttle cable slack at the thumb throttle to bring idle up a touch.
The stock ones filter more dirst than a K&N aftermarket, I would stay with it.
Same as answer to #2 take side covers off to see carb.
Old Jan 19, 2009 | 08:21 PM
500H.O.'s Avatar
You can get a muffler and all kinds of performace upgrades at www.speedwerx.com
Old Jan 20, 2009 | 08:15 PM
DarrenWS6's Avatar
Thank you for the replies guys I much appreciate it. No worries about me putting a K&N on it, i'll never use one of their dust sucking filters. I was wondering if there was anything better than the stock ones. Thanks.
Old Jan 20, 2009 | 08:42 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Mobil 1 oil 0w40w or Polaris. Oil Filter = NAPA 51358, Wix 1358 or Polaris. Recomend using stock air filter. Idle adjustment is a phillips screw attached to a rubber piece by the pull starter. Turn this left or right depending on higher or lower idle. I have had four Sportman 500s and all were /are cold blooded.
Old Feb 21, 2009 | 10:24 PM
Hockeyplayer00's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: DarrenWS6
bump.</end quote></div>
You're on f150online too right?
Old Feb 21, 2009 | 10:34 PM
DarrenWS6's Avatar
Yes I am.
Old Feb 22, 2009 | 12:19 AM
Rickeyparker's Avatar
Use the Uni Filters without Oil and use a sock over it, Their cheap and you could buy a couple every year.
Jmuddin284
Jan 19, 2026 07:16 AM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
79hugger
Aug 30, 2015 02:21 PM
pro94lt
Aug 20, 2015 10:02 AM
