Instrument Cluster
Old Feb 6, 2009 | 11:02 AM
KMKjr's Avatar
Default Instrument Cluster
Fathers hunting partner has a question for all you Cat pros!!
At about 1000 km's, lost cluster (not illumiation but everythig else), replaced cluster under warranty, lasted 250k, happened again and now off warranty, failed again. Dealer will not replace under warranty and tell him that is common.
Don't want to be replacing every year and just want to know what to do?, is there a problem, a repair, something else causing it?
Any suggestions will be helpful.
Thanks in advance.
Old Feb 11, 2009 | 08:59 AM
KMKjr's Avatar
Unplugged battery for 10 minutes and working again!!
Thanks for all the help to the guys on articchat.com.
Old Feb 11, 2009 | 03:16 PM
swampyjunior's Avatar
My manual says to unplug the Instrument cluster for 60seconds then plug it back in. It makes more sense to disconnect the battery. I rememebr reading that the issue is caused by some internal electrical problem on the clock.
Also, if it sits for a long time the internal clock can drain the battery to the point the starter will not work. How good your battery is determines how long it can sit. I think a battery trickle charger or battery manintainance device is suggested.
SJ
Jeff Roper
Feb 1, 2022 11:48 AM
whitty
67
Feb 24, 2021 02:52 PM
tropicalnuts
Polaris Side by Sides
Aug 22, 2015 11:08 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Sluggo
Aug 20, 2003 11:39 PM
