bogging 700
Old May 6, 2010 | 06:48 PM
vw_lover's Avatar
Default bogging 700
hello,i ve got a 700 efi that i replaced the fuel pump on and know it boggs like its not getting enuff fuel it doesnt do it all the time and it doesnt seem to do it as bad if you ease it to it rather than floggin it. i was wondering what it may be? thanks for your help
Old May 6, 2010 | 07:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
was the fuel filter replaced? the pump you got to replace it w/ the same gpm as the stock? just wondering if th fuel pressure would be enough. just a thought.
Old May 7, 2010 | 10:23 PM
vw_lover's Avatar
yea i replaced the filter,i tore it back down last night and found that one of the tabs that hold the regulator in the plastic had broke and it blew the seal out im not sure how to fix the problem maybe zip tie it together,because i dont beleve you can buy the piece thats broke
Old May 8, 2010 | 05:03 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
not sure on what piece, but if you go to a parts break down maybe you can see it and find out if you can buy it. at least you found the issue. good luck.
Old May 8, 2010 | 10:17 AM
jerrymi's Avatar
If you have the old piece J-B weld it back on or fab up a new tab with the J-B that stuff has saved me many times from having to buy a new part because of a stupid brake on a part
Old May 8, 2010 | 08:12 PM
vw_lover's Avatar
Angry
thanks for all your help,i fixed the regulator,but know the pump wont hold pressure so its hard to start and sometimes backfires,the regulator is bad and you cant buy just the regulator you have to replace the hole tank which sucks its 450.00 looks like its gonna be sitting for a while
Old May 9, 2010 | 06:17 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
what did you replace the pump w/ when you relaced it? no way of getting an after market one?
Old May 11, 2010 | 06:51 PM
vw_lover's Avatar
i used the pump that someone on here said would work its actually for a hyndia
Old May 12, 2010 | 06:56 AM
Kerbbirds's Avatar
Not sure what regulator your talking about, I have used the air-tec pumps from the parts store and had good luck with them,maybe you can get what you need from e-bay, they have gas tanks.
Old May 16, 2010 | 09:36 AM
vw_lover's Avatar
the regulator is the black round thing inbetween the pump and the top of the sending unit
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
