TaoTao 125 Stalls when Pressing Throttle
Old Jul 25, 2011 | 08:54 AM
reality4u's Avatar
Default TaoTao 125 Stalls when Pressing Throttle
After about a week of owning the ATV it has begun to stall when pressing the throttle. It starts fine and will idle most of the time ok, but when you press the throttle it seems to choke itself out (bog down) and stall. Oddly enough if I put the choke on it doesn't stall when pressing the throttle and I can rev it up.
I took the carb apart and made sure the jets weren't clogged. After second time doing this it seemed to run ok for a day then the problem came back.
Any ideas would be greatly appreciated, we are on vacation and having 1 son with a working ATV and the other without is a sad situation.
Thanks in advance for any help.
Old Jul 26, 2011 | 09:08 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Welcome to the forum reality4u!
Is there a fuel filter in the gas line? Is it the stock one from China?
Old Jul 26, 2011 | 09:22 AM
reality4u's Avatar
Hi, thanks for the welcome. I am already glad to have found this forum, lots of great info.
Yes the fuel filter is the stock one that came with it. Does is sound like it's letting partilcles through and clogging the jets?
Old Jul 26, 2011 | 09:36 AM
KTM Patrol
Former Chinese POW!
Hi ... your welcome..
Thats what it sounds like to me..and it may be coming apart and clogging something.. part of the Chinese deal is parts that look just like the real thing.. but dont actually work like it.. filters, spark plugs, and rubber are just a few of them..
Old Jul 26, 2011 | 10:52 AM
reality4u's Avatar
thanks, i'll try replacing it. any suggestions on where to get quality parts for these online?
Old Dec 9, 2017 | 08:26 PM
vitalka89's Avatar
I know this was a while ago but checking what ended up fixing this issue? I'm having the same issue with a Taotao 125 quad.
Old Dec 10, 2017 | 03:02 AM
It is almost certain to be dirt or water in the carb. Clean it out and fit a new fuel filter, if it is water, clean the tank out as well (as best you can,) there is dirt or water in the tank that is getting into the carb.
Old Dec 10, 2017 | 09:27 AM
vitalka89's Avatar
I appreciate the response. Is the carb on these pretty simple to work on?
Old Dec 11, 2017 | 04:26 AM
We don't get Tao Taos in the UK unless the UK importer calls them something else, but for all carbs, as little dismantling as possible is my way, and it works. Remove float bowl, remove the jets (two or three) blow through them with compressed air, blow through all passageways with compressed air. Check the jets are clean by holding them to the light, clean out the float bowl, if there is any water in there you may have to empty the tank and get the water out of it too. Re-assemble carb, no altering mixture screws, no new parts unless the float chamber gasket has torn. Some Chinese carbs have "tamper proof screws" on the float bowl, either drill the heads off to get into it, and fit new screws, or buy a new carb instead, but you may need to fiddle with mixture screws and jet sizes on a new carb.
Ronk407NY
Feb 13, 2016 11:05 AM
cdoren
Aug 16, 2015 11:22 PM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
house1
Aug 9, 2015 10:49 PM
fire1998
Aug 6, 2015 02:46 AM
