2004 Sportsman 500HO won 't stay idle in cold weather
Old Dec 16, 2012 | 11:00 AM
sbishop664's Avatar
Default 2004 Sportsman 500HO won 't stay idle in cold weather
hi everyone, i picked up this wheeler this summer and its been working great. Now that we have cold weather (below freezing), it won't idle if i let go of the throttle all the way BUT if i move the throttle 1/8" it works great. Starts right up if i move the throttle just a hair....won't start if i don't move it.
i've attached a few pictures, i believe it has something to do with the throttle...if i stick a piece of paper between the connection, it starts right up and idles fine.
(when i move the throttle an 1/8", its not enough to move the carb cable)
Any suggestions is greatly appreciated!
Sbishop
Attached Thumbnails 2004 Sportsman 500HO won 't stay idle in cold weather-kingsclear-20121216-00010.jpg   2004 Sportsman 500HO won 't stay idle in cold weather-kingsclear-20121216-00009.jpg   2004 Sportsman 500HO won 't stay idle in cold weather-kingsclear-20121216-00008.jpg
Old Dec 16, 2012 | 11:26 AM
TLC's Avatar
TLC
100% this is the problem.Video: Polaris ATV Thumb Throttle Maintenance Tips | eHow.com
You adjust it from under the rubber sleeve on the cable.
Old Dec 16, 2012 | 11:40 AM
sbishop664's Avatar
Thanks TLC, that must be the problem...i'll take a look at it tonight!
Sbishop
Old Dec 16, 2012 | 06:23 PM
bgirard420's Avatar
Video says it all.
Need to adjust your throttle freeplay so the ETC stops sensing it as a stuck throttle.
Old Dec 17, 2012 | 04:39 AM
sbishop664's Avatar
Took me all of 2 seconds to fix the issues....thanks!
Old Dec 17, 2012 | 06:23 AM
Jaster94's Avatar
just think, a dealer would've charged you an outrageous amount of money for that 2 second fix. now that's crazy ain't it?
Old Dec 17, 2012 | 07:14 AM
If a dealer charged for that,they should have been run out of business! I fixed dozens in pick up truck beds and trailers that they drug into the shop parking lot and didn't so much as get the peoples names in a lot of cases! I just got a big kick out of seeing their reaction to what was wrong! Some just laughed,some were po'd that it was so simple. OPT
Old Dec 18, 2012 | 06:07 AM
Jaster94's Avatar
amen brother, amen. i've adjusted a few for several folks myself, didn't charge anything for the "hassle". i just shared the information with them for future reference and to help folks out. thanks OPT! you are the man!
Old Dec 19, 2012 | 02:28 PM
bobx2's Avatar
If I'm not mistaken, that same contact is what energizes the ADC as well. When my adc wouldn't shut off, even with the switch off, I put a small piece of electrical tape between the contacts and that kept the ADC from engaging anymore.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
ranvette
Jul 12, 2015 06:34 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
