rust on crank?
Old Jan 1, 2013 | 12:58 AM
99veesixxer's Avatar
Default rust on crank?
i have the top end off the bike right now and i have a little bit of rust on the crank how do i get that off? scotch brite pad? sand paper? what about the dust getting into the crank? is it ok? or a big no-no?
Old Jan 1, 2013 | 01:42 AM
95wolv's Avatar
Rust on the crank.........I'd say something, but the moderators would probably spank me pretty hard for it.........
Old Jan 1, 2013 | 11:09 AM
Rust on the crank is because of either moisture in the fuel over time or if the top end has been off awhile. You can use emory cloth,scotch brite,etc but hard to keep some of the crap from getting back into the case. If you have some kerosene you can flush the crank case,( when full,pull the case drain plug)then pour a little two stroke oil over the rod and the small holes in the case that lead to the crank bearings. Make sure there is no up and down play on the rod,side to side play is ok. On an older machine you're still taking a chance just on a top end job without replacing with a new rod kit and crank bearings.After having one come back on me for this,I wouldn't guarantee just doing a top end for customers when I was at the shop. Just my OPT
Old Jan 1, 2013 | 11:21 AM
TLC's Avatar
TLC
The Fuji motors are dry sumps not wet sumps like most 4 stroke motors,so the crank is not sitting in a bath of oil.Most of the oil is in the oil tank not the crankcase like other machines.
I guess if it was sitting for long periods it could get some rust.
Old Jan 1, 2013 | 12:15 PM
Unless he's got another atv he's talking about a two stroke 97 250 Trail Boss he's been posting about. OPT
Old Jan 1, 2013 | 03:35 PM
user493's Avatar
Moto Psycho
Something like ... He wasn't using his crank often enough.
Old Jan 1, 2013 | 03:37 PM
95wolv's Avatar
(pointing at jumbofrank) It was HIM............unleash your moderators fury on the infidel !!!
LOL
Old Jan 1, 2013 | 11:55 PM
it had nasty nasty *** gas. will kerosene work to flush out the crank case?? or is gas a better idea? and the push rod is fine no play at all, it just has rust on the crank and i was wondering how to get it off. and i get my crank turned enough
Old Jan 2, 2013 | 06:37 AM
Kerosene will dissolve grease and grime better than gasoline. We even started using it in our parts cleaner at work. It's easier on rubber parts and crank seals. Just fill the crank case,spin the rod around,drain the kerosene and use two stroke oil to coat the lower rod and bearings. OPT
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
