2006 sportsman 500 stalling issues
Old Feb 21, 2013 | 01:13 PM
mike159's Avatar
Default 2006 sportsman 500 stalling issues
when it is cold no issues fires right up and runs great until you shut it off. when you start it back up while its still warm, it starts fine and idles good until you take off, after you go a few feet it stalls. it will restart just fine but will stall again, this will happen for 5 or 6 cycles and then run fine until you turn it off then starts all over again. the check engine light comes on while its misbehaven. have noticed if you let it idle for 2 minutes or put it in neutral and rap the throttle hard a couple times its good to go. can't get it to throw a code.have changed the filter and plug. any ideas!
Old Feb 21, 2013 | 02:16 PM
Sounds like the map sensor harness or connector problem. This was a common thing to happen on efi machines. The wiring is thin,can show a bare wire that may be shorting out that you can repair,but a lot of times the wiring can break internally or have an intermittent problem. Some would do as you machine does,others would backfire,erratic idle,but run good off idle. This is the most common thing to happen other than fuel pump problems.If you have a fuel pump pressure tester you can eliminate the pump as a problem also. It must hold 39 psi with the key on engine not running.If you hear the pump priming up then might be in the map sensor harness wiring. Look at the "sticky" post above this section on efi problems plus here's the link to the heavy duty repair kits. Only The Best
If you narrow it down to a fuel pump problem Airtex has replacement pumps. This is an example. http://www.autozone.com/autozone/par...questid=376721
Old Feb 21, 2013 | 03:06 PM
mike159's Avatar
Default 2006 sportsman 500 staling
thanks for a place to start looking,will check wires and get back to you with the results.
Old Feb 25, 2013 | 04:00 PM
mike159's Avatar
finally got a chance to check the wires, did not find a loose wire but was able to read and understand the codes. it thru codes 45 & 46 bps sensor, circut low input & circut high input. is that the sensor or connector?any ideas, thanks
Old Feb 25, 2013 | 04:08 PM
MAP circuit low and high input code 45 and 46. These are the codes I got (when they did show up) for problems in the map sensor. NOT the sensor itself,but the harness or connector.I'd order the kit and I think your problem will be solved. Only The Best
Old Feb 25, 2013 | 04:22 PM
mike159's Avatar
great news, i will order it tonight thanks for the help. will let you know what happens on the next ride.
Old Mar 19, 2013 | 10:48 AM
mike159's Avatar
got the new harness connecter installed and went out this last weekend on a long ride. had no issues bike ran great, no stalling or back firing in reverse. great job on fixing my problem OPT, your the man! thanks again.
Old Mar 19, 2013 | 10:58 AM
I didn't fix it you did This is still a problem area on all the 500/700/800 efi machines and a lot of people over look it because they don't see any broken wires and assume this connection is good.
Jmuddin284
Jan 19, 2026 07:16 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
