centriugal clutch install help
Old Jan 18, 2014 | 05:23 AM
shanman98's Avatar
My name is Shannon and I just pit a new one way bearing ,shoes and springs in my centrifugal clutch. I have it back on and the but is snug but I can't keep the crank from turning when I try to torque it to 87ft lbs like it calls for..how do I stop the crank from moving so I can't tighten it properly? Thank you
Old Jan 18, 2014 | 09:16 AM
TLC's Avatar
TLC
A trick I use to take the Primary clutches off on snow machines, is a rope down the spark plug hole with a knot at the end of it.
It jabs between the head and piston at TDC , then you just pull the rope back out once your done.
Old Jan 18, 2014 | 03:10 PM
shanman98's Avatar
Thanks..I done that with a chainsaw and thought about it
Old Jan 19, 2014 | 04:22 AM
Only do this on the compression stroke or you could bend a valve.
I replace Honda clutches regularly and use an impact air wrench, just holding the clutch by hand. However, after spending ten years assembling truck axles, I know how to get the right torque by “feel”.
Old Jan 20, 2014 | 06:39 AM
shanman98's Avatar
I did it with a piece of pull cord ..it jammed it enough to get it tight then I hit it with the electric impact. With the pull cord it jammed it but it wasn't big enough so it would let go and not jam right up..shouldn't of bent the valves I hope at least it didn't jamm up that tight.. Nuts tight anyway ...hope for the best and lots of compression with my finger over the plug hole..thanks guys
fordfaithful21
Dec 7, 2015 05:52 PM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
cdstang
Aug 31, 2015 07:52 AM
