opinions needed
Old Jul 30, 2014 | 02:39 PM
lueds's Avatar
Default opinions needed
Hey everyone I have a 2004 yamaha warrior with a bent rod and busted cylinder l planned on tearing it down myself and rebuilding looking for some opinions on what performance parts to buy I would like to make this thing very fast thank you very much for your time
Old Jul 30, 2014 | 09:36 PM
Raptor450's Avatar
If it were mine I would go back with a stock length rod with a JE 366cc piston kit 10.5:1 compression. I've had several warrior engines from mild to wild, and this setup was the best bang for the buck and the most reliable. Keep in mind that comparitively speaking, a Warrior will never be "very fast".
Old Jul 31, 2014 | 02:38 PM
lueds's Avatar
Default loss
So should I cut my losses an upgrade to something bigger
Old Jul 31, 2014 | 10:04 PM
Raptor450's Avatar
If you're already thinking about it then I would. Warriors were the sport trail quad to have in the early 90's, but things have changed alot since then. Why would you spend all that money hopping up a Warrior when you can get a 400EX for cheap, that is already faster and has better suspension right outa the box? The same goes for the Raptor 700's which cost a little more around $3500 for a used one.
Old Jul 31, 2014 | 10:08 PM
lueds's Avatar
Default Raptor 450
Thanks I will be giving this a lot of consideration
Old Jul 31, 2014 | 11:49 PM
HondaR24's Avatar
I have to agree with raptor450. For instance, a 400ex put out a good 7-8 HP more out of the box. That's a big difference for machines in the 20-30 hp range. You'd be very lucky to get an extra 7-8 hp from the warrior without dropping more than the bike is worth. The suspension is also night and day difference, although a 400ex doesn't exactly have the best stock setup either it's still a lot better than a warrior.
Old Aug 1, 2014 | 08:03 AM
LT80's Avatar
LT80 Expert
" very fast"....Maybe consider a 450. Many to be found at a fair price.
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
sara durrant
Jul 6, 2015 05:32 PM
tweeder
Jul 5, 2015 01:57 PM
Mphillips
Jul 2, 2015 07:20 PM
