clutch nut HELP
Old Jun 27, 2015 | 12:23 PM
alix's Avatar
Default clutch nut HELP
hi,im looking for advice on how to take off clutch nut as tried to beat it with hammer(yes will def buy tool nex time)but is there anyway of getting it of now its really stuck all edeges are gone of bolt now so cant bang it with screw driver any more.have pult loads of wd40 on it stil bolt wont turn need help and tips advice would be grate!! thanks
Old Jun 27, 2015 | 09:34 PM
LynnEdwards's Avatar
Electrical Expert
Originally Posted by alix
hi,im looking for advice on how to take off clutch nut as tried to beat it with hammer(yes will def buy tool nex time)but is there anyway of getting it of now its really stuck all edeges are gone of bolt now so cant bang it with screw driver any more.have pult loads of wd40 on it stil bolt wont turn need help and tips advice would be grate!! thanks.
I'm unfamiliar with your engine. Can you (or anyone else with experience on this) verify that the nut in question is not a left hand thread? If it is, all the banging and cursing you've done has only made the nut tighter...
If it is a right hand thread, can you clean it up enough to weld a socket to the nut? You will have to be able completely clean the grease off the surface of the nut where the weld will take place. You'll also have to grind the plating off the socket in question as best you can before welding. Keep in mind most platings give off poisonous fumes during welding, plus they interfere with the weld joint itself, so don't skip this step.
Then weld in in 1 second bursts:
Hold your breath (poisonous fumes)
Bzzt for a second
Walk away and get a breath while it cools
Go to somewhere else on the periphery of the socket and repeat
After a several tack welds you should be able to use a breaker bar on the nut/socket.
The one second tack welds will keep temperatures down away from the actual weld spot so that things don't get damaged by the welding heat.
Old Jun 28, 2015 | 03:16 AM
alix's Avatar
thanks for reply it is a left hand tread.i have being banging both ways to try get losen nut to get it off.is there any other methods to get it of as dont have welder thanks
Old Jun 28, 2015 | 09:22 PM
MPDano's Avatar
That looks bad. At this point, without sacrificing more parts, I would try and take it to a local machine shop to see what they can do.
Proper way is to soak in some type of rust penetrant ( I use kroil), then use the proper socket to loosen using an impact wrench.
Old Jul 1, 2015 | 10:33 AM
Zrock's Avatar
Super Quad Patrol
Did you try a little bit of heat? may have been held on with tread lock. Also did you check and make sure their is not a lock/keeper on it that you have to bend the tabs over on?
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
