2008 Wolverine Rear Arm/Driveshaft Boot Leaking
Hi all. I've got myself a little problem here. My 2008 Wolverine is leaking oil from the boot that covers the drive shaft where it attaches to the bottom of the crankcase and the rear arm. I'm not sure if it is motor oil or gear oil as I have not gotten a chance to see if either is draining. So my first question would be, do any of you know if it's engine related or rear diff related? Secondly, what would be the general process to replace whatever seal is leaking?
The oil is coming from the boot and hose clamp area that make up number 8 and number 10 on this diagram.
Any help is greatly appreciated.
Thanks
Thanks
Thanks
Thanks
So I finally got to tearing it down completely today. Took the rear axle right off.
There was fluid leaking out of the differential at the front where it connects to the arm. I'm assuming that should not be the case?
So assuming it should not be leaking there, then am I correct in saying that o-ring #11 and oil seal #12 from this image should be replaced, and that should hopefully solve my problem?
Lastly, there was some kind of caulking or sealant where the diff met the rear arm that was worn out. I'm assuming it's to help keep a seal and that I should replace it. Anyone happen to know what that might be?
Thanks again for all the help.
Well, frankly, I thought the leak would be from the engine side
. For it to leak "where it appears to be leaking" I'm thinking that at one point the diff may have gotten full of water ( best guess ) as it looks like some rusty "gook" coming out of it, but yes, replace the seals you mentioned and when you re-attach the two castings ( item #2 to engine ), use Yamabond or a quality Permatex brand sealant to seal the two parts together. Of course, thats after a thorough cleaning. Keep us posted..
I've done far more Hondas than Yams, but it is difficult to know for certain where the oil is coming from once the prop shaft is out of the diff nose, as it will start leaking there, even if it wasn't before. That is why my reply was "Gear oil smells different" and you can check that once the boot 8 is slackened off. If it is the diff, then only the diff assembly needs to come off, then you can pry the old seal out and fit a new one.
Ride 4 Ever
Technical and How-To Articles
Jan 29, 2016 01:27 PM
newtonty
Jan 16, 2016 03:09 PM
