more thrawtel exceleration.
Old Nov 28, 2017 | 02:40 PM
kennyj's Avatar
Default more thrawtel exceleration.
1997 Kawasaki 400a prairie
we put a rebuilted kit in carberator adjusted carb settings now atv starts and idales great. the atv runs great when I excellerat from start to about 1\2 way up the thum throtell I can get no more exceleration from the rest of the throtell.
would this mean to install a bigger high speed jet
Old Nov 28, 2017 | 07:23 PM
hydrex's Avatar
I's suspect the main jet (high speed) may be partially plugged. Remove it and blow out with compressed air. Unless you are sure it's the wrong size. For new jets, you might like <jetsRus.com>
Old Nov 29, 2017 | 07:10 AM
scootergptx's Avatar
Supersock
Hired Gun!
Welcome to the forums.
Is it the stock jet, or has someone possibly changed it out?
I agree with making sure it's not just plugged first. If you have a small enough wire, use it to help clean the seat of the jet. More than a few times I've talked with people who sprayed their carbs with cleaner and that was it. Still ran bad. They went back and made sure the seat was clean and it solved the problem.
If that's not it, the good news it jets are pretty cheap.
Old Nov 30, 2017 | 06:51 AM
MNSTORM's Avatar
Agreed with above post^^^^
I had this same issue with my 350 wolverine after installing a carb rebuild kit. Everything looked clean when i took it back apart. I noticed that the needle would not move freely (was sticking) in the seat when i tipped the carb and let the float hang down. I fixed this by dipping a small amount of metal polish on a Q-tip, stuck the Q-tip in a cordless drill and polished the seat. When i was done a sprayed it out with carb cleaner and put it back together. Solved my issue.
srod2222
Sep 14, 2006 10:06 PM
fastblaster00
Dec 30, 2004 12:31 PM
hondarider300
Feb 27, 2004 02:33 AM
macgiver
Mar 27, 2002 01:00 PM
JoJo33
Dec 7, 2000 05:22 PM
