Eiger - ignition problems
Old Feb 24, 2021 | 03:59 PM
hokierider's Avatar
Default Eiger - ignition problems
Pulling my hair out.
2004 Eiger. Started, ran for a minute and backfired. Flywheel magnets came loose and damaged stator. Replaced flywheel, stator and ignition coil. Am getting power to the plug. Plug tester light seems to flash very slowly and dimmer than when I test another bike. Turns over, but will not attempt to start even with ether. Any ideas? Could it be the rectifier? Had such high hopes last night when I put it all back together. Thanks for any advice.
Old Feb 25, 2021 | 02:44 AM
Take the plug out and check if you are getting a spark at the plug itself. Fit a new plug anyway. Also check the TDC mark is at TDC by the piston, it is possible for the flywheel key to move out of place as you fit the flywheel, putting the ignition timing out.
Old Mar 31, 2021 | 10:47 AM
hokierider's Avatar
Good news. Replaced starter. Fired up. Running like a champ.
papa hogg scoot
Sep 1, 2019 03:06 AM
AAB
Sep 3, 2017 02:29 AM
chopperman66
Sep 20, 2011 06:09 PM
Cablerum
ATC 3-Wheelers
Sep 9, 2009 11:25 AM
LiveWire
May 29, 2001 12:05 PM
