up size tires
Old Mar 31, 2021 | 10:53 AM
hokierider's Avatar
Default up size tires
I have an Eiger. Stock tires are 25 x 8-2 and 25 x 10-12.
If I increase the height to 26, will it hurt the power or performance?
Old Mar 31, 2021 | 08:27 PM
Kymco 450i's Avatar
You will loose some low end grunt, it will be the same as going a step higher in gearing. How much power your engines creates will decide on how much bottom grunt you loose.
Old Apr 1, 2021 | 03:46 AM
You can always stick it in low ratio if you need more bottom end grunt. I find the Auto Eigers are a bit low geared anyway so, if it is an Auto, it might actually feel better.
Old Apr 1, 2021 | 07:44 AM
hokierider's Avatar
Thank you both. It is an auto. I was mainly concerned with the additional stress turning the heavier tires may put on the transmission and drive train.
Old Apr 1, 2021 | 03:05 PM
Kymco 450i's Avatar
The most stress will be on the deive belt, but...unless your hill climbing or digging in sand, probably not an issue. If you feel it lugging down go to low for sure...
Old Apr 2, 2021 | 12:36 AM
greg74's Avatar
It depends somewhat on what type of tires you're going with. If its a lighter 26" tire like an itp mudlite at, they won't be a lot heavier than stock 25" tires. I doubt you'll notice much of a difference. If you're going with a much more aggressive tire with bigger lugs, then they definitely will weigh a lot more and you'll notice a drop in performance. I don't think you'll be in danger of breaking anything but it will rob you of a little power.
yvillanz
Oct 12, 2009 12:30 PM
MickJP
Sep 14, 2008 09:48 PM
greeneiger
Feb 6, 2008 09:14 PM
slowneasy
May 15, 2006 10:05 PM
PrarieTy
Jan 27, 2000 05:48 PM
