Yamoto 150cc fuel problem
Old Jun 28, 2022 | 01:16 PM
Travis3's Avatar
Default Yamoto 150cc fuel problem
So I'm close to getting my Yamoto 150cc running but I'm having a problem, if I open the gas, the atv won't start. If I close the fuel line it starts and runs fine until the fuel left in the line runs out. Anyone know what the issue could be? I don't want to mess around with the carburator until Im pointed in the right direction.
Note: my brother cleaned the carb before he gave me the quad and replaced the fuel line. Could it be the size of fuel line he used?
Old Jun 28, 2022 | 01:41 PM
Travis3's Avatar
Default Pics of carb
Old Jun 28, 2022 | 01:44 PM
Travis3's Avatar
Also, any info you can give on the carb as far as what I would look for in ordering a new one would be helpful. I don't have a breather or fuel filter either so I would like to know what to look for.
Old Jun 29, 2022 | 02:16 AM
Looks like the auto choke CD type carb used on most GY6 engines, though any I have seen use a black plastic cover on the dashpot. As I have written many times on here, to clean out carb, remove float bowl, remove jets, clean float bowl, jets and the holes they came from, out with compressed air, re-assemble and try out. No altering jet settings or mixture screws. If you want to fit a filter, put an in line one on. If that first pic is a fuel pump, put filter between pump and carb. Breathers are usually just a piece of pipe going upwards or into air filter box, top end of pipe must not be where rainwater can get in.
Old Jul 11, 2022 | 08:48 PM
Travis3's Avatar
Default *update*
I finally got my Yamoto 150cc running today. It was the Petcock all along. Ordered a new one from Amazon, installed it in 5 minutes and now it's good to go.
hezfast2
1) Engine problems..
May 4, 2022 06:09 PM
DKSmith
May 2, 2021 03:27 PM
hondarider22
Dec 19, 2013 08:29 AM
ewffemt
Apr 6, 2006 08:52 PM
