05 Suzuki Ozark Smoke Bomb
Old Oct 27, 2023 | 08:26 PM
pastorjeep's Avatar
Default 05 Suzuki Ozark Smoke Bomb
Hey guys, just picked up a an Ozark in rough, and I do mean RUFF shape. Cracked frame, cylinder head and cam cover destroyed, plastics painted with metal flake, rims bent up, no key-twisted wires, carb full of god knows what, engine crankcase full of water. Stripped it down and welded frame, new ignition switch, cylinder head, cam, and cam cover. Plastics cleaned, oil changed, new battery and clean carb. The thing fired right up! runs nice, shifts a little clunky but all gears. Good compression, idles good and lots, lots, lots of smoke. If you start it and just idle, no smoke, but if you rev it up...WOW. It is burning massive amounts of oil. Question, can you have good compression rings and bad oil rings at the same time? Could something else make smoke like this when revved? I am going to pull the engine back apart and and check ring gap and see if a ball hone and new rings will fix it. I have a few Yammy 250's, Timber Wolf and Bear Tracker and the Suzuki is definitely a more refined machine.
Old Oct 28, 2023 | 03:21 AM
If the previous owner hacked it that bad, check it has the right dipstick, as the wrong oil level could cause the smoking. Check the engine breather system is OK and, if you do need to take the top end apart again, check valve stem seals and that there isn't a fault in the new head leading to oil getting into the ports as well as checking rings. It is dead easy for part of that oil control ring to "catch", as you lower the cylinder on, and you may not notice.
Old Oct 28, 2023 | 02:23 PM
pastorjeep's Avatar
I changed the oil and it is the right level. It only really smokes bad when revved which leads me to believe it is the the oil rings despite having good compression.
Williamkwebb
Apr 7, 2016 07:13 AM
srwshooter
Mar 5, 2010 12:43 PM
Indianarider
Mar 11, 2009 07:30 PM
mtwolffo
Apr 30, 2008 10:02 PM
justanotherRAPTOR
Apr 6, 2003 07:20 PM
