Rival Trailhawk 10 No Spark
Old Jun 16, 2024 | 01:20 PM
Eduardo58's Avatar
Default Rival Trailhawk 10 No Spark
So according to the wiring diagram shown, I should have continuity from the red/black wire at the cd boxi, through the stator to ground? Currently, it’s open. An I safe to assume this would cause my no start issue then?
Old Jun 17, 2024 | 04:08 AM
Yes, there should be some resistance, often about 450 ohms but not open circuit. Double check by spinning engine on starter and seeing what AC voltage (if any) you get between red/black and earth.
Old Jun 17, 2024 | 11:09 AM
Eduardo58's Avatar
Just tried it….Nothing from the red/black. I tried the Trigger wire just to make sure my meter works and it has a signal there.
Old Jun 18, 2024 | 03:25 AM
Dead power coil then. Worth checking the black/red hasn't a break in it, when you remove the flywheel but it looks like you need a new stator, make sure it is single phase. Most "Honda clones" are three phase, though many only use 2 wires, earthing the third phase.
Old Aug 11, 2025 | 05:57 PM
NH603's Avatar
Default I have a Rival Trailahwk 10 with no spark!!! Did you fix yours?
I replaced cdi box ignition coil and spark plug still nothing.
I'm lost. What did you do to fix yours?
Please help?
Thank you
Jeff
Old Aug 12, 2025 | 02:12 AM
OP tested for a fault before concluding the power coil on the stator was toast. Did you test anything before fitting new parts?
Old Aug 12, 2025 | 03:50 AM
NH603's Avatar
Hi,
Did you find out what was causing no spark?
Thank you,
Jeff
Old Aug 12, 2025 | 03:59 AM
NH603's Avatar
It's not the stator.
Thanks,
Jeff
Old Aug 14, 2025 | 02:03 AM
"It's not the stator."
Right so it has to be the wiring, as you have replaced everything except the stator. I see it has the dreaded "remote box" on it, so that has to be number one suspect. Check that with ignition on and both kill switches set to run, the black/white to CDI is not earthed, assuming it is an earth to kill CDI.
Skilledsamurai
3) General Discussions..
Jul 18, 2023 02:50 AM
Guillaume732
Aug 22, 2019 04:27 PM
Skyhorse
1) Engine problems..
May 14, 2019 01:57 PM
smallquad110
Jul 17, 2012 11:07 PM
thedoc
Feb 14, 2009 05:07 PM
