Lakota prob.
Old May 30, 2001 | 11:41 PM
bigbadlakota's Avatar
I have a 2001 lakota and have had it for about 2 months. There is something wrong with it and i can not figure out what it is. This is what it does when i go to climb a hill or try a wheelie it just boggs out like it has no power. So I took the airfilter out and cleaned it and put it back in it helped a little. I run it a little today with out the airfilter or airbox lid and it did not bogg down or sputter. Any help guys. Any and all help will be appraciated.[img]i/expressions/face-icon-small-sad.gif[/img]
Old May 31, 2001 | 10:24 AM
redd888's Avatar
bigbadlakota, i have the same year lakota and my hasn't done that, if i were you i would take it back from where you bought it and have them fix it.
redd
01 lakota
DG pipe
Baha skid plate
Old May 31, 2001 | 12:28 PM
bermbanger's Avatar
I think the float in the carb is set to low. I don't think something like this will be covered under warranty.
Old May 31, 2001 | 10:17 PM
Any help on what to do to fix it bermbanger. is there a screw or what. please help.
Old Jun 1, 2001 | 09:32 AM
mojaveaddict's Avatar
If taking the air box off makes it ok, then it is running rich. All that extra air helps lean the mixture and gets it closer to the right ratio. The float could be set too high or the needle and seat might not be holding. If it is only two months old it will be covered under warranty. Take it back to the dealer and explain how it runs and what you did.
Old Jun 1, 2001 | 09:57 AM
It fouls plugs like crazy last weekend i bought 2 new ngk's and I put one in there for like 5 minutes and took it out it was blacker than i don't know what.So it some thing to do with the airmixture.
Old Jun 1, 2001 | 11:37 AM
Yea thats just another sign of a too rich mixture. You need some carb work. Make sure your choke is not hanging and staying on.
Old Jun 1, 2001 | 12:55 PM
thank for the help guy.
Old Jun 1, 2001 | 08:42 PM
momar's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img]I have had a 2001 lakota sport since last August and had a problem with the carb. It would run out the over flow hose and would,nt stop unless you turned off the petcock at the tank.Took the carb off and removed the bowl and there was a little piece of white silicone sealant down in the needle valve and held the float open,so if you tear it apart check for stuff like that.
momar's Avatar
[img]i/expressions/face-icon-small-cool.gif[/img]I have had a 2001 lakota sport since last August and had a problem with the carb. It would run out the over flow hose and would,nt stop unless you turned off the petcock at the tank.Took the carb off and removed the bowl and there was a little piece of white silicone sealant down in the needle valve and held the float open,so if you tear it apart check for stuff like that.Text
kwackermann
Jun 24, 2015 10:18 AM
KawasakiLakota
Aug 23, 2000 11:57 PM
blazer1969
Aug 23, 2000 02:45 PM
shockwave
Aug 20, 2000 07:57 AM
cstark
Oct 15, 1999 01:45 PM
