DS on alchohol?
Old Jun 14, 2001 | 03:44 AM
650MANIAC's Avatar
Anybody know of anyone running alchohol in their ds? If so where can you get a carb? And will the stock rod handle the compression?
Old Jun 14, 2001 | 01:41 PM
ScoobyDFW's Avatar
I was thinking about running methanol with my EFI/Turbo, mainly to lower temperatures and avoid detonation. Larger injectors and/or a different fuel mapping would be needed.
Old Jun 15, 2001 | 05:59 AM
BigDodge99's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]Have you considered using water/alcohol injection on your quad scoob? Thats what I run on my blown dodge to run more boost safely. Its supposed to help cool the intake charge by 75 degrees or more.
Old Jun 18, 2001 | 09:39 AM
xray's Avatar
Having considerable experience in running alcohol in blown motors with major mods I would seriously not recommend using alcohol in a stock or naturally asperated DS. Alcohol is for injected motors only and will give nothing but problems in a standard induction setup. Also it is very corrosive to magnesium and its alloys as used in todays carbs.
If you are using a turbo a 50/50 water methanol mix is ideal to give an almost 100% booost to torque if the engine is dialled in properly. The mix should be injected into the inlet air via a small atomizing jet and a high pressure pump, you will most certainly notice the difference in performance.
Alcohol fuel is good given that it is used on the correct setup.
Xray
200oDS, Custom X sereis II, TeamPami CDI, Datel instruments, Renthal bars,K&N in airbox.
Old Jun 18, 2001 | 12:00 PM
jeffnrivercity's Avatar
I once helped a friend tear apart his LT500 that was running alcohol,and I was amazed everything inside was rusted or coated with a orange film of rust,to me the inside of the motor looked like it had been sitting in a junk yard for 10 years.I know most quads that run alcohol have a small purge tank to run gas thru a Y type valve to clean the alcohol out when your done riding,this guy said he purging his 500 but it looked nasty,It made me leary about ever running alcohol.
Jeff
ZapooMafoo
Sport Quads
Jun 13, 2007 06:52 PM
Tpsycho
Jan 3, 2007 10:55 AM
DStroyer
Jul 20, 2004 07:22 PM
esonnen
Jun 9, 2004 12:07 AM
650MANIAC
Jul 31, 2001 10:07 PM
