stripped the hub out on my 300
Old Mar 24, 2002 | 06:18 PM
whoisdig's Avatar
its a '99 and i have gators on it for 6 months. i dont do a lot of hard riding. it went out when i was stuck in a snow drift today.
does this happen often?? the hubs loosen up all the time. all the bearings in the rear have been replaced before the tires were installed.
Old Mar 24, 2002 | 09:50 PM
Ohio250rlover's Avatar
iv heard about of people talk about the rear hub's losening all the time my 250r does it to and they never slay tight ...does anyone have a fix for this??
Old Mar 24, 2002 | 09:51 PM
KNOWSALOT's Avatar
The Facility
This does happen often. The problem is after the hub has been removed, it is sometimes hard to get the axle nut tight and still get the cotter pin to lign up with a hole. Usually to get them lined up and be tight, you have to torque them above factory spec.
When you put the new hub on, grease the splines of your axle. This will keep the hub and axle from grinding on one another if the hub comes loose again. It will not cause the hub to slip on the axle unless your axle splines are stripped as well.
tysonbully
Sep 28, 2015 02:30 AM
ny250r
Apr 27, 2001 06:11 PM
Bayou3004x4
Mar 22, 2001 03:20 AM
brokemybanshee
23
Jan 6, 2001 12:37 AM
