Anyone use the HPD Super duty Clutch button kit?
Old Apr 17, 2002 | 01:32 AM
Todd400's Avatar
Hi guys, Its time for a new belt and I have been running my HPD aggressive clutch kit for about a year now with no problems, Im going to order the HPD kevlar belt and figured it might be wise to go ahead and replace my stock buttons before they break, I was just hoping I could get a little insight from anyone who is using these now and see how they are holding up? From the pics the look alot stronger and dont seem to have an special installation? Anyways just fishing for some info so let me know[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 17, 2002 | 06:53 AM
biggin's Avatar
I don't know about the buttons, but I've used the kevlar belt for 2 weeks at the dunes and have yet to notice wear on post ride inspections. The belt is much harder and stiffer feeling than the stocker,thats why I'm keeping an eye on the clutch surfaces.
98sport 400L
rcr stage 1
hpd clutched and belted
v force delta reed cage
Old Apr 17, 2002 | 09:18 AM
Mike Chero's Avatar
I believe that AZ400L has. From what I hear, he seemed pretty happy with them.
Old Apr 17, 2002 | 10:50 AM
modquad's Avatar
I have run both the buttons and the roller clutch from HPD. There is no comparison to how much happier I am with the roller. Not only the fast and smooth upshift, but the instant backshift does wonders for woods blasting, and all around riding. A big thumbs up on the grin factor.
Ken Thompson
Old Apr 17, 2002 | 10:58 AM
AZ400L's Avatar
I converted from an AAEN roller to the SS button kit after stepping up to the full race mod set up. I was very happy with the roller, but had concerns about the roller holding up to the torque of repeated launches at 4500RPM's. Plus AAEN didn't have the helix angle I wanted availabe for the roller.
The Install was simple, although it does require you do a bit of drilling. I forget the bit size, but you need to drill the existing hole through the back, as the SS button kit comes with longer and beefier screws to secure them. It's all spelled out in the instructions and is quite simple.
I haven't had it apart in about six months, but don't think anything is amiss in there. Besides, replacement pads are only like $2-3 each.
Old Apr 17, 2002 | 12:04 PM
CED's Avatar
CED
My ss buttons have been in my bike for over a year now .They show very little sign of wear.I am very happy with the buttons.I also take off about 4200rpm's.
Old Apr 17, 2002 | 01:07 PM
Todd400's Avatar
Thanks guys, AZ400L, did you need a right angle drill to drill the holes through? Its been so long since mine has been apart I dont remember how much room there is?
Old Apr 17, 2002 | 02:52 PM
CED's Avatar
CED
Todd,there's plenty room for a regular drill.On the back side of the housing where the new screws come thru,you will have to grind the ribs down so the head of the screw will sit flat.The instructions that came with the kit are very clear also.Later.
Old Apr 17, 2002 | 05:36 PM
modquad's Avatar
Todd, the beauty of it all is that the "machining of the clutch is the same on the buttons as on the roller for the HPD products. It is not necessary, but if you have the access to someone who can mill the part, it's much more accurate. Also (this also depends of the level of accuracy you want) you can use a drill guide available at any machinist's supply for backdrilling the pilot holes. The guarentees the bit not to do any angular walking. The HPD roller is also a much heavier duty unit than the AAEN. Really a day and night call when you hold them up to each other.
Ken Thompson
STLyamwar
Jul 25, 2020 04:44 AM
Zehno
Sport Quads
Jan 2, 2016 01:31 PM
erntee61
Aug 9, 2015 02:54 PM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
coolguy420
Jul 10, 2015 01:17 AM
