Is it ok to upshift w/o using the clutch??
Old Jun 10, 2002 | 05:44 PM
Rockey's Avatar
My brother in law said it is ok to upshift without the clutch but you definitely need to use it when downshifting. Whats the word on this??
Old Jun 10, 2002 | 07:30 PM
TheFasterTheBetter's Avatar
Can't wait to see Jeff's post on this one. [img]i/expressions/face-icon-small-shocked.gif[/img]
Do a search on Tranny and you will probably find something. I think Jeff even has some pictures posted at Extreme Garage if I remember right.
Make sure your brother in-law puts it in writing.
Old Jun 10, 2002 | 07:35 PM
BLACKDS's Avatar
Jeff has a automatic in his, he doesn't believe in clutches!!!using one would only slow him down.
Old Jun 10, 2002 | 08:15 PM
Rockey's Avatar
Thanks for the warning.
Exactly what part broke? If it was syncros and such then it makes sense.
If it was the gears then that has more to do with too much power and too much traction, not shifting.
Old Jun 10, 2002 | 09:18 PM
HardCrash02's Avatar
I upshift with no clutch all the time and have had no problems
Old Jun 10, 2002 | 10:29 PM
Hightower's Avatar
You cannot upshift a DS without using the clutch. You can downshift with no clutch, as long as you're not under load. If you upshift a DS with no clutch, you will be replacing the shift forks - this is what breaks. I grew up on Hondas - you can upshift all you want with no clutch, but not a DS. The transmission is not built the same - don't do it - or you will lose the forks.
Old Jun 10, 2002 | 11:17 PM
Uglyman32's Avatar
im still getting used to my MX boots with the DS but so far i have probably upshifted about 20 times by accedent because it went in so verry easy. does it still F*** it up ?
Old Jun 10, 2002 | 11:18 PM
Uglyman32's Avatar
without the cluch that is
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
