Clutch Springs
Old Nov 1, 2002 | 04:09 PM
RebelDS's Avatar
Default Clutch Springs
I noticed reading below about a problem with weak choke springs. I have just recently purchased a 2003 650 and wondered if the problem has been fixed on the 03 models. Also, I was riding with some others on my old 02 model and the muffler was under water while I tried to get out of a hole. I had to let it idle while going from reverse to low and when it went to idle, it would die. Some of the others I was riding with thought that it shouldn't die because the muffler was under water because they say their's doesn't. Is that just an adjustment problem and how should I go about fixing it? Thanks.
Old Nov 1, 2002 | 05:41 PM
nyroc's Avatar
Don't know the 03 choke.
The stalling with water up to the tailpipe is reduced when the idle is set lean, and/or idle is set faster.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
