Help Bike doesn't start??????
Old Dec 11, 2002 | 03:25 PM
CrazyDemon's Avatar
Default Help Bike doesn't start??????
I had the problem about five or six months ago, but had that fixed (it needed valve adjustment). The dealer said the vavles were almost out (smallest shims), after that, he said that i would have to get a whole new head. Is that true??? Now i'am have the same problem it had five months ago. I have to pull start it, it would start, but wouldn't start after i shut it off, but it well start if it is warm enough. Help me out I miss riding it.
Old Dec 11, 2002 | 05:33 PM
bombrider's Avatar
Check your battry, i had the same thing and it turnd out to be a died sell.
Old Dec 11, 2002 | 07:28 PM
918sTaxi's Avatar
Take off the airfilter or airfilter hose, put your hand over the carb and try starting it. It worked for me.
Old Dec 11, 2002 | 07:49 PM
Eaglecollector's Avatar
I too am at the smallest shim size on my intake valves (2.00mm shims) I would think that new valves would be the fix for this. Not an all new head. What about it guys. Im OK at that shim size so far. But will I be looking at a valve job or new head and valves when the time comes.
CrazyDemon, when you do get it running do you have a power loss. Im guessing you do. Your valve or valve are not closing all the way. Hence the hard starting. Also when it does run your running in a decopression mode. (Valves not closing).
You must have more than one valve not closing all the way or it would start much easier. It's perty simple to check the valve clearances. You should do that and at least eliminate that possibility.
Old Dec 11, 2002 | 09:47 PM
KenDS's Avatar
Eaglecollector,
A valve job will do it. It can easily be remedied by adjusting stem length at that time.
Old Dec 16, 2002 | 04:27 PM
CrazyDemon's Avatar
[img]i/expressions/face-icon-small-confused.gif[/img] If I was to reseat the heads, would that help?????? I don't think the air filter would be the problem or the battery. The last time I got the valve adjusted they said the intake side (both sides) were to tight??????
Old Dec 16, 2002 | 05:47 PM
KenDS's Avatar
Yes, if you put new valve seats in the head it would give you more adjustment on the valves. But that is not cheap. Check your valve clearance first, it's easy. If the valves are too tight and you are at the smallest shim then the head will have to come off, at that point a machine shop can inspect the valves and seats and determine if seat replacement make sense, if they are in good shape they can trim the valve stem height and get you the clearance you need for much less money. If you don't have a shop manual, now would be a good time.
Old Dec 17, 2002 | 03:45 PM
CrazyDemon's Avatar
Does anyone have an Shop maunal, That shows how to adjust the valves. I've hear that there is two possible top dead centers on a DS 650???????? Also I have another problem with my breather hose.... Oil comes out of it, it gets all over my valve cover........ what would cause that to happen????[img]i/expressions/face-icon-small-smile.gif[/img]Text
Old Dec 17, 2002 | 04:55 PM
glamisds650's Avatar
go to my site glamisdunes.net for valve adjustment procedures and checks.
whitty
67
Feb 24, 2021 02:52 PM
txkevin
Sep 21, 2015 02:02 PM
Bassassasian101
Jun 10, 2015 06:23 AM
1000gade
May 27, 2015 12:37 PM
Codyv20
May 26, 2015 09:51 AM
