stripped out oil plug
Old Dec 30, 1999 | 11:05 PM
exlax250x's Avatar
can i use a heli coli to fix it
Old Dec 30, 1999 | 11:06 PM
exlax250x's Avatar
i really need your help here guys
Old Dec 30, 1999 | 11:21 PM
whisky's Avatar
Whats heli coil settle down
Old Dec 30, 1999 | 11:31 PM
Trailblazer96's Avatar
A Heli-Coil will work great. I used one once to fix a sparkplug hole and it worked. You can get one at an auto parts store.You will have to buy the kit that is the size of your oil plug and all you do is retap the hole and thread the helicoil in. Use threadlock on it or RTV silicone for a good seal.
Old Dec 30, 1999 | 11:32 PM
exlax250x's Avatar
its a insert that makes the stripped hole smaller they have one under tech tips
Old Dec 30, 1999 | 11:33 PM
exlax250x's Avatar
thank you it is such a relief
Old Dec 30, 1999 | 11:55 PM
exlax250x's Avatar
i forgot to ask, how much do they cost
[This message has been edited by exlax250x (edited 12-30-1999).]
Old Dec 31, 1999 | 02:26 PM
I think the kit I got was around $30 it was expensive because it comes with the tap and the tool to put the insert in. There might be cheaper ones though.
Old Dec 31, 1999 | 03:20 PM
theowl's Avatar
Try one of the automotive type self tapping oil plugs. They are cheaper and some of them even have a magnet built in that will trap any steel particles in the oil. They are not metric (you may find a metric available) but this is not a problem as they create their own threads as you insert them. They run about $10.00 and require no special tools. I have had good luck over long term use with them.
Old Jan 1, 2000 | 09:51 PM
exlax250x's Avatar
what i ended up doing was getting a self tapping plug with a piggy back incert in the middle so you wont have to mess with that soft allmunim when you change oil
Hankey Pankey
May 1, 2018 01:33 PM
Shainasmash
May 8, 2017 06:38 PM
Hankey Pankey
Aug 17, 2015 05:01 PM
Captjay
Jul 23, 2015 12:33 PM
