Prairie 650 loose screw
Old Feb 20, 2003 | 08:39 PM
gtchief's Avatar
Default Prairie 650 loose screw
I was looking at my 650 today and noticed a bolt lying next to the pull starter. I looked around the area to see where there might be a screw missing and saw an empty screw missing in the cylinder head on the pull starter side. The area is just about right below one of the mounting tabs on the exhaust heat shield. If anyone has any idea as to what this is supposed to be holding in or if it is actually where the bolt is from please let me know. If not I'll just take it into the dealer. Thanks guys
Old Feb 20, 2003 | 08:47 PM
FLEA's Avatar
Go to buykawasaki.com and look at the diagram for the cylinder head and compare the drawing to what you actually have and you will know where the screw/bolt goes and what it hold on.
buykawasaki.com
Old Feb 20, 2003 | 08:56 PM
gtchief's Avatar
I did that. I can the place I think, but I dont see anything going into it there. But that doesnt mean nothing does go there.
Old Feb 20, 2003 | 10:49 PM
Kawi650's Avatar
what size is it? and lenght?
Old Feb 20, 2003 | 10:54 PM
gtchief's Avatar
Not exact but its about 1.5 inches long and maybe .25 inches diameter with a fine tread. I think the head is 10mm(a guess) and silver. Any ideas?
Old Feb 21, 2003 | 08:26 AM
gtchief's Avatar
Anyone have anyidea about this? It's down until I get it figured out.
Old Feb 22, 2003 | 03:10 PM
gtchief's Avatar
Ok, I went to the dealer today and checked out a 650 to see where the screw may have came from. Found out it is from the timing chain tensioner. I put it back in, but should I be worried about anything with it now?
Old Feb 22, 2003 | 08:10 PM
NovaKaw650's Avatar
2 bolts hold the tensioner in place; you lost one. No problem.
Old Feb 22, 2003 | 11:41 PM
gtchief's Avatar
Nova
Thanks, Another question maybe you can help with. Above the location of the chain tensioner bolts, there is a rectangular indentation on the head, maybe an inch by 2 inches. There is a treaded hole there but no bolt and I am wondering if there is supposed to be one. Do you have any idea if there should be and what it does? Thanks again.
ReconBayou
Oct 16, 2019 02:24 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
