Starter
Old Jan 26, 2004 | 03:45 PM
Turfguy's Avatar
Default Starter
My starter just "clicks" when I push the little green button. Its had been doing it once in a while than eventually with repeated attemps fire as usual. That would mainly happen when it was cold. Now it does it even after its been running for a couple of hours. I assume the starter is bad, does anyone else have this problem or know how much one costs. I use my quad for snow removal, the pull start usually fires it up with the first or second pull, but those 500cc take some pulling, like the button much better.
Thanks for any input
Tim
Old Jan 26, 2004 | 07:39 PM
Wires's Avatar
Default Starter
You can find the starter, and rebuild parts from:
http://www.brownsleisureworld.com (it's in Canadian Dollars though). There is another one in US dollars, but I forgot the link.
You don't want a new starter (unless you want to sell a first born). The site lists it at $432 CND. You can usually rebuild it.
You might want to check the battery. Is it charged good? Are the connections good from the battery and to the starter? The clicking noise is usually from low voltage to the starter, which is usually caused by either a dead battery or poor connections.
Usually, a dead starter is just plain dead (it doesn't click). Turning it a bit may get it going again if it's a bad winding or something like that. You also might want to check the solenoid. Not sure where it is on the parts list though. It'll supply the power to the starter when you hit the button.
An easy check is to hook a wire directly to the starter, and touch it to the + on the battery. If it turns over the starter is fine. It could also be a bad starter button.
Hope this helps.
Old Jan 26, 2004 | 09:58 PM
Bear4570's Avatar
Default Starter
Usually when tjey just click, it's the starter solenoid bad and not the starter. The switch on the grip closes the solenoid which feeds power to the starter. The work after clicking it several times also say solenoid.
Old Jan 26, 2004 | 09:59 PM
TORK's Avatar
Default Starter
Most likely you have a bad solinoid or connection, starters don't go bad often and when they do they usually don't click (as stated by Wires).
Old Jan 26, 2004 | 10:06 PM
2Fast4U400ex's Avatar
Default Starter
i wish i knew something about starters....or i wish my brother was home. He rebuilds starters and alternators for a living. I'll ask my bro tonight when he gets home and let you know tomorrow
Old Jan 26, 2004 | 10:31 PM
TORK's Avatar
Default Starter
When brushes lose contact you will still have current at starter, need to check for current at solinoid, If you have current on both sides of solinoid Check at the starter.
Old Jan 27, 2004 | 12:26 AM
maximus's Avatar
Default Starter
i have had this happen many times on my old sportsman 400. i would bet my left leg that it is your brushes, which is not very expensive to fix
Johnny Mac
Aug 15, 2019 03:13 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
wrencher82
Sep 28, 2015 10:02 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
