Holding its own
Old 10-20-2000, 10:04 PM
Andy Bassham's Avatar
Well if thats the case, then your dealer is an idiot like most other dealers are. I have never seen a 7" factory wheel. Mine are 12x6.5". Its stamped on there clear as day just like it is on yours. BBC's 454 wheels are 12x6.5 on the front, and 12x8" on the back. And once again, it is stamped on the inside of the wheel. If they are trying to tell you that AC never used a 12x8" Titan wheel, then they don't know what they are saying.
As far as the weight goes, if the factory wheel only weighs like 6lbs, then it is lighter than the ITP Magnum aluminum, and you should seriously consider picking up another set. The Magnums weigh 7 lbs each. This according to Dirtwheels, who may sometimes be wrong, but probably isn't in this case.
Old 10-21-2000, 12:25 AM
BONER's Avatar
Well thanks for correcting that for me-- I might look into getting a set of rear 400 wheels then(so I don't need spacers up front). If there cheaper than the Magnums I probaly will, unless I all of a suden decide I want to make my cat look better.
r1pilot83
Utility ATVs
15
11-25-2019 11:39 PM
Pehter
09-04-2016 08:22 PM
wrencher82
09-28-2015 10:02 PM
MikeyBoyesq
09-22-2015 10:02 AM
meddy0388
09-09-2015 06:41 AM
Quick Reply: Holding its own
