2005 Artic Cat TVR 500 Temp Light
Old Oct 6, 2010 | 07:29 AM
Jamievech's Avatar
Default 2005 Artic Cat TVR 500 Temp Light
Hey Everyone I'm new here and a new A C owner. Wondering if anyone could tell me why My temp light Is always on from when i start the machine to when i shut it off???Think it Might be a sensor problem but ?? Also the vent hose keeeps coming off the breather on the gas tank an dgas spills out is there a way I can keep that from happening Thanks in advance
Old Oct 6, 2010 | 02:44 PM
cupsz71's Avatar
Cool
WELCOME to the forum.
Couple of thoughts since this is obviously a used machine -but NEW to you?
1. YES it could very well be a bad sensor,or a broken wire
2. I'd check your coolant level. If it's VERY low on coolant this could throw the sensor off. Re-fill and let your machine IDLE up till the cooling fan kicks in to get any air out of the system - THEN put your cap on
3. speaking of fan - DOES IT COME ON? You may also have a bad fan motor...or BLOCKED fan from debris. I believe that if the ECM DOESN'T receive a signal from the fan it will trip the temp symbol.
4. pull your green 30amp MAIN fuse and disconnect the battery for about 5 min. Tends to re-set the gauge pod and a general ECM re-set.
Give your new ride a COMPLETE once-over. Check all your fluids and pay special attention to your wiring harness along the frame. Lot's of "pinch" points - especially just after the fuse block and up along the handlebars connecting to the gauge pod. A chafe'd wire can short out and throw all sorts of goofy readings.
As for your vent hose........new clamp.
Hope this helps
my .02¢
Good luck!
Old Oct 7, 2010 | 07:21 AM
Jamievech's Avatar
Thanks Cupsz71 I will check it all out I appreciate Your Response
txpedsrt1
Feb 3, 2017 08:07 PM
sportsman2005
Technical and How-To Articles
Aug 19, 2015 10:52 AM
scram5050
Aug 19, 2015 02:19 AM
DeFox500
Jul 26, 2015 06:32 PM
ltrmc02
Jul 22, 2015 04:50 AM
