Water pump issue on Arctic Cat 700 EFI?
Old 02-06-2014, 09:41 AM
sisco22's Avatar
Default Water pump issue on Arctic Cat 700 EFI?
Hey guys,
I am needing some help badly! When I add coolant to my 700 it goes straight into the oil. I changed the head gasket and ended up buying a used water pump off ebay. I replaced the water pump and poured coolant in it and it was still coming out of the oil drain hole. Took the water pump back off, poured water in the radiator and it came straight out of the water pump. Does this mean I have a bad seal in the pump? I really want to get this fixed and over with, anyone have any advice??
Thanks in advance!
Old 02-07-2014, 08:37 AM
Rude Robert's Avatar
sounds like the head or head gasket is damaged sorry
Old 02-11-2014, 04:11 PM
frankmako's Avatar
crack in the head? bad head gasket? these are the two areas that i would look.
Old 03-17-2014, 08:55 PM
papa hogg scoot's Avatar
Sounds like maybe an bad waterpump drive bearing and seal IMO
Nondem
02-22-2020 12:20 PM
SDR-II
09-29-2015 01:06 AM
KimSJoh
14
07-18-2015 07:20 PM
Gtsordo
07-13-2015 10:38 PM
Mikea1978
07-04-2015 12:37 PM
Quick Reply: Water pump issue on Arctic Cat 700 EFI?
