250 AC problems
Old Sep 22, 2001 | 01:16 AM
lil250cat's Avatar
I saw the problems post...just wanted to add my woes here.
99 AC 250 2X4...worked fantastic, loved it.
got a bit hard to start when it was cold.
wouldn't idle after stream crossings
dealer had no clue, wanted to clean the carb after i told him i did
went home & cleaned the carb AGAIN, no luck
turned out to be the intake valve, no big deal..had to adj twice now
front end got loose...brakes wore out
when replacing brakes, found lots of trouble
replaced front bearings, seals, upper ball joints, & spindles
left side rear has play too...maybe right side bearing in engine too
Anyone else had to replace all this after 18 months??
Tracy in central PA
Going on a poker run anyway, gonna run the rear loose!
Old Sep 22, 2001 | 05:00 PM
chunkyboy's Avatar
hey dude i had the same problem with mine the valves was to tight i got some gauges from my dealer reset the valves now it starts better and runs free but i havent had any other problems my is a 2000 i had about 14 months we have a 2001 4x4 400 but we ride this one more it rides much better and steers easer and burns half as much gas that 400 burns some fuel the 400s valves where tight in it too the dealer set them nothing like a great dealer i got a 400i ordered i wanted the irs and seclect 4wd plus the fan dont run all the time on the rad i hate that blows fuses in the river every time i cross it needs temp switch but noth of my problems 2001 400 4x4 2000 2x4 250 1997 220 bayou
Old Sep 22, 2001 | 08:29 PM
BONER's Avatar
Why did you replace your spindles??
Old Sep 22, 2001 | 11:20 PM
CornDog's Avatar
I have an Arctic Crap 250, and hate it. It is going to break down no matter what, like mine. Another thing, don't listen to Boner because he owns an Arctic Cat dealership and will say nothing but good things about them.
Old Sep 23, 2001 | 01:11 AM
minehunter's Avatar
Gosh Boner You must be the youngest Cat dealer in the Country. Corndung says you own one. Funny I thought you just worked there part time.
That cornhole has a lot of straight dope or else he is a one. I know he's not over about 13 years old, but he's wise beyond his time, and smart too. Or maybe just a smart***.
Old Sep 23, 2001 | 02:26 AM
BONER's Avatar
Yea, I never would have thought I could own an Arctic Cat dealership at 17 years old. Who would have thought?
Old Sep 25, 2001 | 10:04 AM
lil250cat's Avatar
I had to replace the spindles because the rear seal had worn grooves in them.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
