Pull cord snaped
Old Jun 17, 2004 | 06:49 PM
sharpie's Avatar
Default Pull cord snaped
my rope looked fine, but up inside that rubber boot where it always sits when your riding, it just rubbed on the slide and thats where it broke. i probably could have jsut shortend my old rope, but i dont like to fix things that way. so i just got a new rope. the hardest part has to be pushing the rope throught that little hole in the handle. the best way to tighten the spring is to buy a few extra feet of rope and fill that pulley as full as you can get it, then jsut pull it out untill it goes around 8 full turns, clamp the rope with some vice grips, and you have plenty of slack to work with too. when i cut the rope i melted it alittle, then cut it after it hardend with some side cutters, works good.. well, i dont know if this is any help to you, i'm just bored out of my mind at work so i type.
Old Jun 18, 2004 | 08:57 PM
PlatinumDogg's Avatar
Also, if your having trouble getting the rope through the little hole, jus drill it out like 1mm bigger or so, i did and the rope went through awesome, my .02 C
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
black798
Sep 9, 2015 07:42 AM
awer1968
Sep 8, 2015 11:02 AM
