200x clutch
Old Mar 3, 2005 | 11:25 PM
paulie83's Avatar
Default 200x clutch
my clutch seems fine in first gear but when i shift into any other gear it slips if i get on it if i feather the gas i t starts to grab do i need to adjust it or put in a new clutch?? if a new clutch is neede can i just put in the friction plates?? thanks
Old Mar 4, 2005 | 02:07 AM
MY86ATC350X's Avatar
Default 200x clutch
i have a good used clutch for 83-85 200x complete clutch assembly with basket. pm me if interested.
Old Mar 4, 2005 | 05:35 AM
ThrashAndCrash's Avatar
Default 200x clutch
First, what exact oil are you using.......Second, is there any free-play in the clutch cable? Third, yes you can just install the friction plates if the steel plates still look good, but not recomended.
Old Mar 4, 2005 | 05:26 PM
paulie83's Avatar
Default 200x clutch
hey im running 10w 40 there is no play in the cable
Old Mar 4, 2005 | 06:31 PM
Default 200x clutch
but is engine oil for wet clutches? if its not drain it and use motor oil for wet clutches. i use Valvoline 10w-40 for wet clutches, and 20w-40 for summer(hot days).
Old Mar 4, 2005 | 06:36 PM
paulie83's Avatar
Default 200x clutch
its just regular 10w 40 is the oil you use formulated purposely for these clutches??
Old Mar 4, 2005 | 06:41 PM
dragracer789's Avatar
Default 200x clutch
You have to have some play in the cable or the clutch wont fully engage.... Probly your problem
Old Mar 5, 2005 | 11:54 PM
Default 200x clutch
you should be able to move the clutch lever (out-most point) 3/8 to 3/4 of an inch before it moves the clutch arm(freeplay). I stick around the 3/8 + a hair. If you are too tight, adjust the cable. If it is too tight, it is just like riding with your clutch partially pulled.
Old Mar 7, 2005 | 11:28 AM
GlennJ's Avatar
Default 200x clutch
10w-40 is fine. As long as the oil is NOT "Energy Conserving", you'll be all set. Engery Conserving oil has friction modifiers that don't play well with wet clutches. Energy conserving oil usually has a starburst logo on the bottle.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
