85 big red locked up?
Looks like you will have to pull the case cover off. This is not a problem but putting it back on can be a challenge if you have not done it before. The reverse shaft and spring usually come off with the cover and it is a bit tricky to put back in place. If you tip the bike on its side you can do it without draining the oil but it might be a good idea to change the oil anyway if it has been sitting for a while.
