84 200s smoking bad
84 200s smoking bad
thanks roxz. thats what i was thinking too. i like that 200x, i had a86 200x. got it in 89, stolen in 90. cops found it about 6 miles up the road about ayear later during a huge drug bust. it was in about 1000 pices. motor blown and fram hacked up in pices. wish i still had it.
84 200s smoking bad
man that bites. Yeah I got it off of the internet and pretty much got screwed on it. The guy lied about it and then I was emailin him to tell him what was wrong with it and he never replied back. The nerve some people have to lie to people just to get a few more dollars.
84 200s smoking bad
chek the piston -to cylinder clearance before you put rings in it ,it might need a bore and new piston
dont forget the valve seals!! if they are bad it will use oil from there as well
if you dont have a valve job done atleast lapp them with valve grinding compound
to make sure your new topend is up to par
if you use old piston at least get a new wristpin and berring(for piston)
--or berring( if applicable,) depends on the machene, i cant speak for every 4 stroke ever made
seeing that im not Jesus,and don't have all that knowledge
but i don't think there all like lawn mowers lol
84 200s smoking bad
why tear a motor down that far just to reuse the old piston? look on ebay and find a cheap NOS oversize piston and rings, have the cylinder bored and install new guide seals and lap the valves but I will bet you the timing chain is worn out too so I would change it while it was apart . should run like new then
84 200s smoking bad
jrooker6
04-23-2016 07:36 PM
