ATC200 Help!
Old Jul 22, 2006 | 08:08 AM
HondaMechanic's Avatar
Default ATC200 Help!
none
Old Jul 22, 2006 | 10:58 AM
lawnboymelvin's Avatar
i have a clymer manual and i dont build three wheelers there banned fom being made so. and all chains have the different coloured link because my D.I.D chain has one. it helps with timing when it is at top like the rest of the marks. im trying to help this guy out on his three wheeler so why dont you 2 back off[img]i/expressions/face-icon-small-mad.gif[/img] im doing it correctly and you guys are just confusing people. your comments or arguments are not wanted on this topic please move on.
Old Jul 22, 2006 | 11:14 AM
arizonatractor's Avatar
Nothing like a kid that knows it all
Old Jul 22, 2006 | 07:49 PM
Joshwfl's Avatar
How do I know which way the cam is supposed to sit? The gear has the "O" mark, but the cam can go one of 2 ways, rotated 180 degrees. Neither mounting hole has a mark as to which lines up with the mark on the cam gear.
Old Jul 22, 2006 | 08:39 PM
  #15
none
Old Jul 22, 2006 | 08:50 PM
  #16
When it is on top dead center there is no pressure on the valves, the pin that holds the advance in place needs to point up. When everything is correct cam lobes should face down and adjust valve adjusters so you have 0.002 inch or 0.05 mm of clearance. When its together how tight is the chain, if its loose you will have to adjust the chain tensioner. Adjustment is as follows once you get it running, start engine and let it reach operating temp. shut it off, remove rubber cap located just behind the cylinder on the left side of the crankcase. Restart engine and let idle, loosen the adjuster bolt. The tensioner will automatically adjust. Retighten the bolt and put rubber cap back on
Old Jul 23, 2006 | 02:20 PM
  #17
Joshwfl's Avatar
Ok, so I can't find the T mark on the flywheel. Could I be looking in the wrong spot? Anyone have a photo? Thanks for all your help so far!
Old Jul 23, 2006 | 02:52 PM
  #18
ok on the block by the pull start there is a little cap. flat screw driver will screw it out then move flywheel untill you see the t.
Old Jul 23, 2006 | 03:57 PM
  #19
none
Old Jul 23, 2006 | 04:09 PM
  #20
Joshwfl's Avatar
Thanks guys, I really appreciate the help! By the way, it's a 200es.
Kre4tur3
Mar 28, 2012 03:24 PM
KNOWSALOT
ATC 3-Wheelers
Dec 13, 2004 03:27 AM
KNOWSALOT
ATC 3-Wheelers
Mar 1, 2004 01:15 AM
KNOWSALOT
Feb 19, 2004 12:39 AM
