timing on 110
timing on 110
With engine warmed up
get an inductive timing light
connect to a battery (Normal automotive timing light)
remove the plug with screw driver on left forward side of engine case
remove CDI cover plate on cly head
set timing to the F mark at idle
To advance or retard timing loosen the screws on the pickup plate and rotate accordingly
This is shown in the manual and is simple
Good luck
Ray
Good luck
Ray
