MX Radials
Old Jan 21, 2001 | 05:59 PM
Banshee350Twin's Avatar
I am getting a set of these tires up front and am wondering how to get them the same heigth as my tires now.
Now i have stock 10X5.5 rim and 21-7-10 Bandits.
The radials are 19".
My question is...how can i make my radials the same height as my tires are now? Would 12X5.5 rims solve this?
I have 20" rear tires and dont want the front being lower then the front for obvious reasons. And no i do not want 18" rear tires!!
Any info would be appreciated!!
Thanks in advance
Old Jan 21, 2001 | 06:18 PM
sock front rims are 7X10...ten being the heigth <G>
Old Jan 21, 2001 | 09:58 PM
54warrior's Avatar
Your tires now are 21x7-10. That means 21" tall, 7 wide, 10" rim. The 19" tires are 19" tall, and fit your 10" rims. They do not make a 21" tall radial, nor one to fit a 12" rim.
What i don't understand is why you don't want the 18" rear tires, the fronts ARE MX radials, so i am assuming you ARE racing MX. The 18" rears are the hot ticket for motocross. If you aren't planning on racing MX, i would suggest not even getting the radial, get Holeshots, razrs, etc..
Hope this was helpful.
Old Jan 26, 2001 | 01:14 AM
collegefunded250's Avatar
Actually, they DO make 12" radial front tires. Pro racer Nic Granlund uses them. They are MUCH taller than the 10" radials. My local quad shop, Quad Central, sells them. Check out their ad in Dirt Wheels.
#70
Old Jan 28, 2001 | 03:19 PM
trx300EXR's Avatar
My ?? is, what is the advantage to the taller radial. I LOVE my 19".
Old Jan 28, 2001 | 05:00 PM
nacsracer40's Avatar
Is there any differences between the Marshall Radials and Riken radials and if so what are they? I just picked up some Marshalls and was just wondering. thanx
-Batman-
'86 250r
LRD pipe/silecer and heavy motorwork, tag x5 bars, pep steering stabilizer/shocks, laeger a-arms/swing arm, marshall radial, turf, douglas/champion beadlocks, nac's mud caps/graphic kit/seat cover, ac pro pegs/bumper/grab bar/skids
Old Jan 30, 2001 | 04:05 PM
GriffsFSR's Avatar
If you are racing MX the best choice for front tires is radials. There is nothing better out there. And if you think there is I would like to hear why. As for what kind, since they have not been making rikens for probably two years now, I would go with the kumho radials. They are grooved much like the rikens where. And many places carry them. One I know for sure is K&K ATV.
Chris
MX 400EX
Old Jan 30, 2001 | 06:23 PM
dual-sporter's Avatar
if there is no better tire out there for MX, why are radials better? is it b/c they don't deflect in hard cornering?
i'd like a more technical explanation... i'm debating going that direction on the front later on & want to know more about it.
Old Jan 31, 2001 | 01:43 AM
Blaster668's Avatar
I use the radials but I have been hearing a lot about the new holeshot MX fronts. From what I hear is that they are better than the radials and actually work in the mud too. About half the pros are using these tires this season. I haven't tried them yet.
Sep 30, 2015 01:37 AM
Snyd
May 24, 2002 10:18 PM
ScoobyDFW
Feb 24, 2002 01:32 AM
OldmanWheeler
Nov 14, 2001 05:00 PM
lonestarbanshee
Mar 12, 2001 06:16 PM
