CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
2001 traxter 500 starter clutch question
Old Aug 29, 2020 | 09:05 PM
armed hiker's Avatar
Default 2001 traxter 500 starter clutch question
Okay I am not sure if this fits expert or general but I just picked up a 2001 traxter and the starter clutch is been diagnosed (by a dealer) as bad. I am a pro motorcycle mechanic but have very little atv experience (no brp) . so a quick heads up on whats ahead of me.
1. where is good place to grab a factory manual? I prefer factory and it could be on disc or flash drive.
2. after watching a couple videos on youtube I am not sure if it is best to pull the motor or do it in the chassis. I am leaning towards pulling it and doing it on the bench vs crawling under it but what say those that have done it?
3. Any things I should be aware of if I am going to be in the starter clutch area or have the motor out? Ie: other common wear items I should inspect while I am there?
4. is it normal the pull start is almost impossible to pull or do you think it related?
Thanks
ghost civic
Jan 15, 2020 07:43 AM
marsrover
1) Engine problems..
May 29, 2012 12:38 PM
skellig1
Dec 2, 2011 10:55 PM
racinjsun426
Feb 18, 2010 05:16 PM
jmswat
Jun 24, 2006 08:11 AM
