What's up with Alcohol anyway??
Old 05-21-2003 | 06:02 PM
TyreSpinner's Avatar
Default What's up with Alcohol anyway??
I'm just curious. Everybody is talking about quads running alcohol. I've never seen such a thing where I live.
What does alcohol do, and how is it used? (Mixed with gas, 100% alky??)
And is it safe on the engine??
Old 05-21-2003 | 06:24 PM
KMDuner's Avatar
The reason most people run alky is because it is a lot cheaper than race gas. Alky is not mixed with gas, only with a top end lube and or nitro.
Also it makes your bike run a lot cooler. As far as being safe on the engine, as long as you take care of your bike it should be fine, AZSand has ran his bikes on alky for years.
Old 05-21-2003 | 07:05 PM
biggerisbetter's Avatar
KMduner is absolutely right.
Also when you switch to Alky you have to increase to size of your fuel jets to almost double, this is because ALKY has alot more Oxygen in it thier for you will need more fuel to compensate for it. This is GOOD and BAD, the good thing is that your Tuning of your engine is MUCH more forgiving, So tuning your carb everytime you change elevation is not needed as much for optimium performance. The down side is that it cuts your fuel mileage almost in half.
Like KM said, alky gives a slight increase in power(especailly in the low/mid range),and at the same time your quad will run cooler.
Biggerisbetter.
Old 05-21-2003 | 08:24 PM
dsracer666's Avatar
is it mx legal?
Old 05-21-2003 | 09:45 PM
Cool, thanks for the replies.
So your saying Alky replaces 110 octane race fuel??
Jeff
Old 05-22-2003 | 01:34 AM
MrMeaner's Avatar
One thing to remember is that alcohol gets in your oil so you have to change it more often. I also use an IV bottle to run gas into carb before I put it up at the end of a ride. Alky will make the metal corrode so dont leave it in the carb. I tried it and loved it. I bought another flatslide to setup just for gas. Now Im selling it. I love the Alky. RWR has the jets in stock.
Old 05-22-2003 | 01:43 AM
Hurycne's Avatar
if you use a 45 then drill out the needle tube the one he gives is not big enough.
Old 05-22-2003 | 11:50 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
[i]Alcahol is the nector of the gods[img]i/expressions/face-icon-small-happy.gif[/img]
Old 05-22-2003 | 12:03 PM
MrMeaner's Avatar
I got a tip at LS Snakehunt to take out my pilot. It made a big difference. Just dont run one.
sugarhead
06-15-2002 09:04 AM
pudjumper
04-26-2001 02:11 AM
cowboy
04-18-2001 04:22 PM
b370
14
05-01-2000 01:51 PM
Quick Reply: What's up with Alcohol anyway??
