Have you tried to remove these?
Old 01-22-2004, 01:25 AM
Cammer's Avatar
Default Have you tried to remove these?
Old 01-22-2004, 01:28 AM
Cammer's Avatar
[img]i/expressions/face-icon-small-blush.gif[/img]
Doah,
Lets try this again. Has anyone tried to remove the rear tire studs? I stipped one and need to replace it. I just can't seem to get enough torque on the 8mm allen wrench. Any ideas?
Old 01-22-2004, 02:26 AM
DuneMe's Avatar
You may want to try the allens that are attached to a socket.
I've replaced one and don't remember it being that tough but, I probably used the socket from the start. That yellow Loctite that comes on them is some tough stuff.
Old 01-22-2004, 05:14 AM
busmechanic's Avatar
along with using a ratchet drive allen. use a good tool brand. snap on, mac, matco. the cheep ones will just twist the allen stock off. you also might try a impact driver.
Old 01-22-2004, 09:51 AM
DCryder's Avatar
I'd try heating the threads with a torch, usually the loc-tite will turn to dust. I know this worked on my motor mount bolts.
Old 01-22-2004, 09:54 AM
DCryder's Avatar
BUT, if your threads on the studs are damaged then the threads in the hubs will probably be damaged when you remove them.
Be Careful!!!!!
Old 01-22-2004, 03:22 PM
Cammer's Avatar
Thanx Guys,
I really stripped them bad to the point that there are no grooves left on the stud. I just need to get them to loosen in the hub. I will look for a 8mm allen socket and try that with the heat and see what happens. I just can't believe how freakin tight that thing is on.
Old 01-22-2004, 06:21 PM
QUADMAN650's Avatar
use a regular set of vise grips it will work
Old 01-22-2004, 06:30 PM
rldbobcat's Avatar
I had to use a chisle to get mine out. I broke off a matco allen even when I heated mine. If the stud is really bad now anyways, take it to a welding shop and have them weld a nut onto the stud then you can screw it out.
Old 01-22-2004, 08:23 PM
Cammer's Avatar
I am a little concerned about heeting the aluminum, any tips?
Quick Reply: Have you tried to remove these?
