Rear axle carrier question
Old 07-03-2004, 12:56 AM
SANDMAN430's Avatar
Default Rear axle carrier question
sounds like you will be fine
Old 07-04-2004, 12:57 AM
LowRecoil's Avatar
k, one last question, how do I get the carrier out to heat in oven? It has flared ends on both sides so doesn't seem to be able to slide out (left side is brake rotor mount, right side is ridge). Rear bolts (2) on swingarm are already removed.
Old 07-04-2004, 03:32 PM
LowRecoil's Avatar
I've tried prying slightly on the swingarm to get the carrier out but it's not working. Do those side pieces on the carrier remove allowing it to slide out?
STLyamwar
07-25-2020 04:44 AM
toonces
07-28-2015 01:58 PM
tporath
07-11-2015 12:31 PM
rcappie4
07-10-2015 04:54 PM
Rider252
07-06-2015 03:37 PM
Quick Reply: Rear axle carrier question
