Traxter Transmission Problem
Old Mar 5, 2005 | 05:39 PM
Jake519's Avatar
Default Traxter Transmission Problem
I finally got my traxter but have had a problem!
When i go to shift from reverse to forward or park ect. It freezes up and won't shift. When i've been doion is shutting the atv down and shifting, then starting it back up which i shouldnt have to do! Does anyone know that the problem is?
Also there is a little dial that says RES, ON, OFF. What is this for?
Thanks
Sorry for the questions, i bought the atv used so no manual![img]i/expressions/face-icon-small-sad.gif[/img]
Jake
Old Mar 5, 2005 | 06:52 PM
Doctorturbo's Avatar
GOT BOOST!
95% of the time this is because the idle is set too high. Being that you can turn the quad off and get it in gear eazy tells me that the percentage will go up to about 99.9% that this is the cause.
The dial is a fuel valve. Off means, well........just that, off. On means, well.........on. And res means reserve, about a gallon or two after you run out of gas in the on position.
Old Mar 5, 2005 | 08:17 PM
Jake519's Avatar
how do you change the idle? Is it hard to do or can i do it myself?
Thanks DoctorTurbo
(Sorry if these are basic things, im new to all this!)
Jake
Old Mar 5, 2005 | 09:06 PM
GOT BOOST!
Easy pleasy.
#1 Start you quad up and get it up to operating temp.
#2 Take your seat off and set aside.
#3 See the black plastic cover on top of the carburator? It has two philips screws holding it on and is about 2" in diameter. (I'm trying to help you ID the carburator in case you don't know where it's at.)
#4 On the left side of the carb down low is a **** that is about 1/2" in diameter. It's silver looking and has a philips head on the end of it. The **** is attached to a spring that looks like a hose.
#5 Make sure your choke is OFF and start your quad up and turn this **** counter-clockwise to a low idle.
#6 Put your seat back on.
#7 The most important step. Go ride your great quad and have fun!!!!!!!!!!!!!!!! Hope I was clear enough?
Old Mar 5, 2005 | 10:00 PM
Jake519's Avatar
Clear as a bell!!!
Thanks, ill do that tomorow!
greg74
Sep 10, 2019 03:03 PM
Captjay
Jul 23, 2015 12:33 PM
shewshew989
Jul 14, 2015 03:09 AM
tporath
Jul 11, 2015 12:31 PM
bikedad3
Jul 2, 2015 02:15 AM
