Lectron tuning.
Ok, got the drag pipe on. I will get pics up soon. My question is with the jetting I have in, Im having a problem, when I give the quad some throttle and let off its taking the quad awhile to come back to normal idle. Its like it is loading with fuel and staying at a higher rpm than normal idle. Any Clue??
Were you rich on the needle when you were running the regular pipe to begin with? I think your needle might need to lean up 1 turn maybe 1 and a half. I think I had the same symtoms when I went too rich or too lean on the needle. It may not be on the power jet if your only reving it up half way.
I think the metering rod is too rich.
With the ct pipe my bike was a hair lean.. Plugs light light brown, little white on the tips of the plug. 222, sugguested that i should turn the metering rod 2 times torwards the richer side. So I did, but I didnt get to do a plug check, with this setting.
Yes, it does it at half rev. Didnt want to upset the neighbors at 10pm tonight. Will give it a shot in the morning.
Thanks Mario.
Thanks Mario.
your metering rod is too lean. I have the lectron on my yfz now. Awesome carb! Check out this page for some help
http://www.lectronfuelsystems.com/rod_adjustment.htm
the500bansheepilot
Feb 5, 2002 03:18 PM
